Hello guys,
I just got a brand new A10M printer, which has two FANs inside the extruder and the third FAN located on the front side of the extruder - outside. The problem is that the two FANs located inside the extruder (at its left and right sides) do not seem to work at all. I couldn't make them turn on neither from the software (like Repetier and Cura) nor from the printer itself. The front FAN does work fine though.
Has anyone experienced the same problem with these two FANs on A10M? Could you please advise if there is any way to turn them on?
I hope it's not a problem with the board itself and the issue could be fixed somehow
Thanks in advance!
A10M - Two FANs inside the Extruder don't work
Re: A10M - Two FANs inside the Extruder don't work
Hi, You can contact your sales to replace the fan.
If you purchased from an agent, you will need to contact yourself;
If you are buying from here,
please provide the address, order number, and email address you purchased.
I hope this can help you.
Thanks for your reply!
The FANs are not faulty as I tested them both by opening the main board and powering the FANs by 12v directly. Both of them turned on without an issue. The problem must be either with the board or I was hoping there could be something in the firmware to be modified to make the FANs run.
Do you have A10M too? If you do, could you please let me know that all the FANs located in the extruder worked for you right out of the box and you didn't have to change anything to make them work?
Thank you!
Thank you!
Hi, If the fan can work normally, it may be a problem with the motherboard port.
You may need to replace the motherboard.
Normally, the fan will open normally.
Yeah, I have the same suspicion that the problem is with the motherboard
Hi, The problem should be the adapter plate of the extruder,
because the interface of the two internal fans is there
and you can replace it.
Has anyone experienced the same problem with these two FANs on A10M? Could you please advise if there is any way to turn them on?JohnDoe777 wrote: ↑Mon Aug 19, 2019 3:59 pmThanks for your reply!
Thank you!auto clicker word unscrambler jumble solver
amekassa wrote: ↑Sun Aug 25, 2019 7:55 pmHas anyone experienced the same problem with these two FANs on A10M? Could you please advise if there is any way to turn them on?JohnDoe777 wrote: ↑Mon Aug 19, 2019 3:59 pmThanks for your reply!
Thank you!
Hi, You can remove the hot end and replace it.
teste de velocidade da internet
Hi there,
this is a very good blog I appreciate your work. thanks for sharing such a useful information.
Visit my blog
Visit my blog
