install 3D touch how to?
LuongTa
Post by LuongTa » Thu Aug 15, 2019 5:55 am
I'm a new and over 70 and only be a user 7 days ago I bought an A10 until now I cannot set up my printer to print any things it is about the leveling, I decided to buy a 3D touch to install as seen on youtube and don't know how to, please help 123 firmware software ext.
Thank so much for every helps.
Old but young to learning :lol:
Re: install 3D touch how to?
Post by William » Thu Aug 15, 2019 9:13 am
:D Hi, For the leveling of the print,
you need to adjust the four corners of the print platform.
The distance between the reference nozzle and the hotbed
is the height at which a sheet of A4 paper can move normally.
For specific operations, you can refer to this:https://www.youtube.com/watch?v=a3eCEiqF_00
For the installation and testing of 3D Touch, you can refer to this:https://www.youtube.com/watch?v=_RtsZDbR2po\
I hope this can help you. :)
LuongTa
Post by LuongTa » Thu Aug 15, 2019 10:26 pm
Thank so much, but I try and try and cannot get the right point too high too low PLA stuck print about 3-5 layer and the model loose from the bed very very hard work 2-3 hours with the setting, look every Youtuber leveling the bed, I now kept the A10 and will try again after I fresh enough to start again.
Thanks for your help, Dear.
Post by William » Fri Aug 16, 2019 9:04 am
Hi, This print result may show that you need to level the hotbed again.
:D
LuongTa
Post by LuongTa » Sun Aug 18, 2019 11:30 pm
Many thanks, will try again after finished works and have more time to play with the A10 :P
Post by William » Mon Aug 19, 2019 9:24 am
:D
:D
