Tricolor Hotend
Moderator: vert
Ricky1966
Re: Tricolor Hotend
Post by Ricky1966 » Tue Feb 19, 2019 11:57 pm
@ _kaktus_
Kaktus, just another 3 questions :
  1. first, hotend is 12 or 24 V?
  2. second, if I must change psu, I can split hotend wire for multiple resistences?
  3. third, which model are stepper motor for extruders on A10M?
Re: Tricolor Hotend
Post by _kaktus_ » Wed Feb 20, 2019 12:17 am
Hey.
:D
ad. 1
The hot-end heater has a resistance adapted to the main power supply.
So if your main power supply gives 12V then ...
ad. 2
It can be divided, but this solution is not good. Depending on how you connect the heaters of many hot ends ...
You need to know the consequences. :roll:
Basic knowledge of electronics, how to connect resistors and how to perform calculations in this area will be useful here.
At this point I would like to draw your attention to ...
We return to the circuit diagram. ;)
Note that each extruder connector can control the heating of the hot end.
So you don't have to divide anything because it's already done. :D
ad. 3
ooojjj
In this respect, my knowledge is too little, for a prosaic reason.
I do not yet know these models of printers.
Unfortunately, no description of the printer available in the web shop contains this information. :roll:
But we can ask a colleague vert to check this information.
vert, would you like to help us :?:
Ricky1966
Re: Tricolor Hotend
Post by Ricky1966 » Wed Feb 20, 2019 12:51 am
Tks, but supply is 220V, DC 24V,360W, right? Then, hotend is 24, or not?
Ad2 I can take PSU, maybe is better a PSU 220V DC24 480W.
Re: Tricolor Hotend
Post by _kaktus_ » Wed Feb 20, 2019 1:30 am
Yes, in this case the manufacturer has equipped your printer with a heater for 24V DC.
If you expand your printer with more power, the power supply will be better.
A small example of how to estimate the power balancing.
Measure the resistance of the hot-end heater.
Ihot end=U/R
U = 24
R = resistance of the hot-end [in ohms].
In the same way, count the current drawn by the heater of the heated bed.
When you add these values to each other you will get the power demand for the components that need it the most.
It is known that there must be a reserve of power, for electronics and stepstick and stepper motors.
Re: Tricolor Hotend
Post by _kaktus_ » Wed Feb 20, 2019 1:31 am
Remember that for many hot-end heaters, you have to calculate many values of the consumed current. Then sum them up.
Ricky1966
Re: Tricolor Hotend
Post by Ricky1966 » Wed Feb 20, 2019 2:39 am
Tks, I remember Ohm's law, I'm enought old to remember what I've study many and many years ago, but don't remember what I've eat yesterday :D :D :D
Re: Tricolor Hotend
Post by _kaktus_ » Wed Feb 20, 2019 3:10 am
:lol:
And I am as old as I feel. :roll:
So I am still 24 years old, and no more than that. :P
When selecting the power supply power, pay attention to the fact that even under maximum load it should not give more than 90% of its power.
Ricky1966
Re: Tricolor Hotend
Post by Ricky1966 » Wed Feb 20, 2019 4:42 am
Also I'm old as i feel, about 100, 150 y.o. but brain... ohhh brain is tooooooo old :) :o
Re: Tricolor Hotend
Post by William » Wed Feb 20, 2019 9:52 am
@ _kaktus_
@Ricky1966
1. The hotend of the A10 is the 24V type
2. The hotend's heat bar is 35~40W,
3. The extruder stepper motor of A10M is this type
GTA2 motor.png (611.34 KiB) Viewed 1740 times
Re: Tricolor Hotend
Post by _kaktus_ » Wed Feb 20, 2019 11:56 am
Haha, you can always rely on William in need.
谢谢
:D
Users browsing this forum: No registered users and 33 guests
