Marlin 1.1.9 with & without bltouch + TMC2208
I need help to make work my printer with the news drives TMC2208 for X,Y,Z,E0
Re: Marlin 1.1.9 with & without bltouch + TMC2208
Yes, I have all mounted, but I wish optimizes the firmware of somebody need I can send it
How is it going on?
Dose it work with your printer?
the printer goes well and very quiet even, I had to adjust the Vref of the drivers and the steps of Extruder, now I think I lost some step on the Y axis.
But think that maybe the problem is cura because I print the same piece two time and all time I get the same defect
- 0A06BC0E-06B7-4A24-A6F2-0679CE6D7856.jpeg (347.16 KiB) Viewed 10107 times
I didn’t try
You can try to use the slic3r then you can compare them :d
