Hi there,
is there someone out there who would share her/his E3D v6 hotend mount?
I did search on thingiverse... but I cant find one.
Need it for the classic A10 (Not A10M etc...)
A10 - Simple E3D v6 hotend mount
Re: A10 - Simple E3D v6 hotend mount
Right... this could fit. Simple to mod.
Thx
Thx
If your head cage as the fans on each side and five bolts on top you can fit it in place of the geeetech one, the five bolts clamp the heatsink.
I have just fitted one, used the original heat block with a new heatbreak ( thread size is different on the geeetech one larger). In the kit it came with five heatbreak's one all metal others ptfe tube, I am using a ptfe one at the moment and get very good prints.
Hope this helps.
Hope this helps.
help i was just wondering after you installed your e3d v6 how did you get to tune the pid, for some reason mine wont tune
You refer to the reprap.com tuning it
open your firmware and change pid max to 128 then auto tune
