I assembled my new geeetech duplicator last week and he printed well.
Today, I changed the nozzle and after turning the printer on, The Display shows "Err: MAXTEMP Bed" - but Nozzle and bed are cold:
237 degree - Bed Temperature is displayed!
159 degree - Extruder-Temperature is displayed!
Repetier-Host log-file
19:44:06.141 : Error:Temperature heated bed switched off. MAXTEMP triggered !!
19:44:06.141 : Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
Even if I remove the bed-cable form bed and/or remove it from board - the same error still occures.
Does anybody has an idea to solf this problem?
237 degree - Bed Temperature - Error:Temperature heated bed switched off. MAXTEMP triggered
Re: 237 degree - Bed Temperature - Error:Temperature heated bed switched off. MAXTEMP triggered
This may indicate that your measuring circuit is not working properly.
Somewhere there may be a short circuit or poor contact.
I would check the circuit of the thermistor in the modified device carefully.
Thankfully! This is absolutely astonishing and delightful post. This post is much similar to the Daft Punk Jacket article. I’m pleased to share the appreciated information.
- Contact:
Great post, you have pointed out some fantastic details , I too conceive this s a very fantastic website Hotmail
