While Printing Nozzle Stops, Display shows "M105"
Freisl
Post by Freisl » Wed Apr 03, 2019 4:36 am
since one month im the owner of the Mc2. All good so far.
Today the first problems.
I use Ultimaker Cura 3.6.0.
What happens....
1.Starting to print
2.after a while the nozzle Stops and u can see in the Display of the Printer the command "M105"
3.So if i do nothing the print is not continueing.
4.So i press the Button near the Display. Printer continues with the print.
This behavior is new, what is it?
Before i had 2 prints, each of them was 20hrs with no Stop....
Is Cura sending for some reason the Command "M105" for getting the extruder Temp? Maybe becaus of a lost Signal while printing(for example temperature Sensor broken)?
Greetings Chris
Re: While Printing Nozzle Stops, Display shows "M105"
Post by William » Wed Apr 03, 2019 8:14 pm
You can attach the gcode file(The forum support zip type file).
Then we can help to check it.
Or you can use the slic3r to slicing it then test it.
