Replacement parts - cable and fan
Drawler
Post by Drawler » Thu Apr 12, 2018 4:57 pm
Hello, I'm Vicente Martinez, from Spain.
I ordered a Mecreator 2 3D printer on May, 2017, via Amazon (order 407-8204653-8865903, 4th of may, 2017) and It has been working ok lately.
I have some problems with two pieces. The fan has been broken and I can't find for a replacement with the same 3-pin connection. (other fans available online have bigger connections and don't fit)
Is there any possibility of buying / ordering a new 3-pin fan?
There's a photo of the broken fan:
https://imgur.com/aDO7F2Z
In case there is no way of ordering a new fan. ¿what is the 3-pin connector type? JST 2.0? JST-ph? JST-XT?
Another important issue is the cable connection between the main body and the extruder. It has a broken contact. I fixed it temporally by a smal welding, but I would like to get a new intact cable.
You can se the cable at these photos:
https://imgur.com/IRr1GkM
https://imgur.com/kKiQUHn
https://imgur.com/M9iXATB
Is there any way of getting a new cable? It is a very important issue for me.
Again, if I can't order it... what's the denomination of the cable for ordering at an electronics shop? It's a 12-pin cable but I don't know the connector type name.
Thank you very much in advance.
Regards,
Vicente
toffetto
Re: REPLACEMENT PARTS - CABLE AND FAN
Post by toffetto » Sun Jun 24, 2018 8:52 pm
Hi, did you find it?
I need it too!!!
Gingko
Post by Gingko » Wed Jun 27, 2018 3:55 pm
I need it too!!!
What's your printer model, also Mecreater 2?
This printer needs a 24V fan.
matt_ch
Post by matt_ch » Tue Jul 31, 2018 1:23 am
Why 24V ? Picture says 12V, 0.09A, 3Pin, 40x40x10mm. Looks like the extruder fan (not the part cooling one - which has PWM).
According to Geeetech-Wiki (http://www.geeetech.com/wiki/index.php/GT2560), the fan 1-3 connections work with 12V. The PWM-fan is not specified (but may be 12V pk too ?).
Or is there something wrong ? Have you measured it ?
8ung
Post by 8ung » Thu Jan 24, 2019 2:54 am
works perfect
https://de.aliexpress.com/item/3-Pin-40 ... 2e0eljgNay
Users browsing this forum: No registered users and 1 guest
