Problems whit the Software!!!
viprit
Post by viprit » Mon Mar 04, 2019 8:03 pm
have got the Prusa I3 Pro W and the Objekts are not the best ones. I think the sofware is the Problem. I will upload a new Software whit Arduino IDE
but there is an eror massage:
Code: Select all
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
from sketch\thermistortables.h:4,
from sketch\Configuration.h:792,
from C:\Users\levin\Downloads\Marlin\Marlin.ino:33:
#define X_MAX_PIN -1
#define X_MAX_PIN 24
#define Y_MAX_PIN -1
#define Y_MAX_PIN 28
sketch\pins.h:2958:0: warning: "Z_MAX_PIN" redefined
#define Z_MAX_PIN -1
sketch\pins.h:1375:0: note: this is the location of the previous definition
#define Z_MAX_PIN 32
Re: Problems whit the Software!!!
Post by William » Tue Mar 05, 2019 2:43 pm
You need to use the Arduino 1.0.1 upload it then it will work.
