Print quality on i3 pro W
Gingko
Re: Print quality on i3 pro W
Post by Gingko » Fri Aug 10, 2018 4:06 pm
Derekchong wrote:
Thu Aug 09, 2018 7:38 pm
I will try to put a shim in the spring as suggested. What do u mean my work table is not level? Is my print bed not level that lead to the clicking sound? :roll:
From my understanding, if the nozzle is too close to the heatbed, the gear might click because the resistance is too heavy to push down the filament.
Derekchong
Post by Derekchong » Sun Aug 12, 2018 10:59 am
Means that my bed level is not even?
Derekchong
Post by Derekchong » Sun Aug 12, 2018 11:02 am
I tried the shim. It seems like the sprint is too tight to extrude any thing....now the nozzle is clog. How to accurately level the bed and nozzle beside the using paper?
Derekchong
Post by Derekchong » Sun Aug 12, 2018 2:52 pm
Does a clog nozzle give that sound? I test the bed it is a paper thick distance...what else can i do to stop the click, make the abs stick ( been using hair spray). Somthing the filament jus making loop around the nozzle...😯
Post by _kaktus_ » Mon Aug 13, 2018 8:47 pm
This situation may also occur when the printer loses steps by moving the Z-axis mechanism.
The gap between the head nozzle and model will then be created incorrectly. It will simply be too small. :o
The melted filament will not keep up with the flow through the nozzle. During this time, the extruder tries to pump a new portion of the filament ...
We already know the rest.
How to diagnose such a situation?
During the operation of the printer, I suggest to observe the clutches to which the trapezoidal screws are attached.
You will see on them whether one of them rotates to a lesser extent.
:D
axman
Post by axman » Wed Aug 22, 2018 1:32 pm
I was having the clicking sound. Then I realized the filament was getting hung up feeding into the extruder. If I make sure the filament has a good clear path so it can't get hung up, it works fine. Just a thought.
Derekchong
Post by Derekchong » Wed Aug 29, 2018 12:43 am
Can i just ignore the clicking or popping sound? By the way my first layer was a messy. How do i solve this 1st layer messy. See my attached photo. Printing in abs at 0.2 layer height.
1st layer height
keyser187
Post by keyser187 » Tue Oct 02, 2018 6:44 pm
What speed are you printing at? Also what is your first layer speed? Because that makes a big difference to your first layers sticking
