Z axis can't goes up or down+Abnormal movement
Admin
Post by Admin » Tue Mar 20, 2018 3:37 pm
If you find Z axis can't move after you assemble your printer, you can refer to this.
I suggest you take off the threaded rods, then move Z axis from LCD.
If one motor jams, you can swap two Z-axis motor cable connector on the main board, check whether the problem will change from one motor to another motor.
If two motors jam, I suggest you swap Z-axis driver with a good-working driver.
If two motors can work well, I have some tips for you.
1. Please remove the smooth rods and the thread rods on a table and check if they are bent].
If the rod is not bent,
You can add lubricating oil for the rod
2. Please tighten the screws of the coupling. The correct mount way:
3. The left Z-axis height should be same as the right Z axis. And you can refer to this post.
http://www.geeetech.com/forum/viewtopi ... 917(thanks
4. Maybe the A4988 of Z-axis has not enough power to drive the motor. And you should increase the voltage of A4988. you can refer to this post.
http://www.geeetech.com/forum/viewtopic ... 7&t=17038
5. You should loose the Z brass nut a little.
6. Check this area(Linear Bearing:LMH8LUU)
Please do not tighten the screws too tightly
7. Check the thread rod type of Z axis
For T8 rod.You can send Gcode"M92 Z400" and then send"M500" to save the setting
For M8 rod. You can upload the official firmware directly
8.You can use a file to polish this hole in the i3-08 part
wthile
Re: Z axis does not go up or down.
Post by wthile » Wed Mar 21, 2018 2:09 am
if you losen the "yellow" nut would that not cause Z axis wobble?
wthile
Post by wthile » Wed Mar 21, 2018 11:02 pm
I followed these instructions and this worked well. I used synthetic gun lube on the threaded rods and all works well now. I have another problem but I will create another post for that.
LenFischer
Post by LenFischer » Sun Apr 01, 2018 11:54 pm
I had problems with my z axis not moving right after my build. It seemed to be a combination of the threaded rods not moving smoothly, and the motors and shafts not being properly aligned. I solved the first problem by removing the threaded rods, spraying them down with WD-40, and running them through the threaded z-axis nut repeatedly until they moved smoothly. I solved the second problem by raising the couplings for the threaded rods so there is approximately a 1 cm gap between the top of the stepper motors and the bottom of the coupling. This solved it for me.
RaySkye
Re: Z axis can't goes up or down+Abnormal movement
Post by RaySkye » Tue Sep 04, 2018 3:17 am
I am having this issue but it appears that the upper brackets (Part i3-08) is pushing the rods out of alignment. How do I go about getting replacements for this part? I have a feeling that the ones I have are slightly off.
I will try the steps in this thread and let you know the outcome.
Post by William » Tue Sep 04, 2018 9:55 am
You can contact the technical@geeetech.com
to send you the stl files for I3-08
RaySkye
Post by RaySkye » Tue Sep 04, 2018 9:57 pm
This solution would not have helped since I was not able to print.
I was able to partially resolve the issue with lubrication though.
I have to be very careful at the start of my prints since the Z axis has a tendency to un-sync and bind. Once it starts it is pretty decent.
Now I just have to figure out how to get the layers to actually stick instead of flaking off. That is an issue for a different topic though.
RaySkye
Post by RaySkye » Thu Sep 13, 2018 7:55 am
Resolved the issues. Turns out there was a stripped nut on the left brass nut. It caused the rod to bend to the right and out of alignment. I was able to remove the nut (the hole is wrecked) and adjust the remaining bolts so everything is aligned now.
If someone else runs into this problem it might be a good idea for them to start with the alignment and work out from there.
N_O_O_D_L_E_S
Post by N_O_O_D_L_E_S » Sun Aug 02, 2020 9:54 pm
I am having a similar issue, which has utterly baffled me. When controlling the Z axis from repetier host, it moves around fine, but the second I click the home button it stops and starts making a horrible grinding noise. I have tried lubricating the rods and aligning them again, but as far as I am aware it can't be the hardware as it works fine until it tries to home. Any advice is greatly appreciated. Thanks :]
