Easyprint doesn't talk to the printer
axman
Post by axman » Thu Aug 16, 2018 12:32 pm
Printer is I3 Pro W. If I use Arduino IDE the printer responds fine. For example, if I send G28 g-code to auto home it does it. But in EasyPrint I configure the com port and the printer type. When I click Connect the printer shutters a little and refreshes the LCD display on the printer so I know it's done something, but the Control page doesn't do anything. If you click the Home button, the printer does not home. I tried clicking a few others and they don't do anything either. Below the XY buttons is says "7 Command Waiting". Also, if I select Printer Information page, it says Machine Type is unknown, Firmware and SN are blank.
EasyPrint is version 1.2.0 that I just downloaded from the SourceForge link.
Re: Easyprint doesn't talk to the printer
Post by _kaktus_ » Thu Aug 16, 2018 1:17 pm
What value have you entered in the baud rate parameter :?:
axman
Post by axman » Thu Aug 16, 2018 9:56 pm
In the Arduino IDE I used 250000. I couldn't find any way to set it in EasyPrint.
axman
Post by axman » Fri Aug 17, 2018 10:03 am
I looked again, more carefully this time. :oops: Anyway, I found it and changed it to 250000 and everything started working. Just finished my first print. Woohoo! Thanks for your help.
Post by _kaktus_ » Fri Aug 17, 2018 2:10 pm
hey hey axman.
I haven't even managed to help you yet. :D
Applause for your perceptiveness and for solving the problem by yourself. ;)
