Printing High Problem
Re: Printing High Problem
Ok, you finally have a different model.
In this case, check the setting of your model in Slicer.
That it is not raised above the surface. Or, that it is not located below the surface.
I use Cura and Slice3r , an there is no option to change the startpoint high.
You have temporarily exhausted my pool of ideas.
Try to think carefully about what we were talking about.
