block printing after a 1 and 50 minutes
gpau
Post by gpau » Thu Apr 05, 2018 5:27 am
I put n print a piece of sd and after 1 and 50 the printer stopped. I stayed on the light at 210 degrees and the bed at 45 degrees. I had to reset to turn off the print (the printer is not connected to the PC)
How come from this problem?
Solutions.
Thank you
Re: block printing after a 1 and 50 minutes
Post by William » Thu Apr 05, 2018 7:25 pm
I think you should check the motor temp
If it were too hot,you need to adjust the voltage of the A4988
You can decrease the A4988 to 0.7V then have a try
gpau
Post by gpau » Thu Apr 05, 2018 9:05 pm
if I'm not mistaken I think they are at 0.82
