Serial Interface IIC I2C TWI 2004 204 20x4 LCD Dis
dandlion1
Post by dandlion1 » Sat Jun 28, 2014 9:09 am
Just got this 20x4 LCD board (JND2004A) with your GEEETECH LCD1602 Serial interface module. I can't get it to work with any of the sample ("Hello World") Arduino sketches I can find on line. All I get is 2 lines of block characters (all pixels on) - looks like the first and third line. The back-light will come on for a while - then blink - then go off.
Can you please provide spec sheet and a sample Arduino Sketch for this module.
Thank you very much.
techsupport
Re: Serial Interface IIC I2C TWI 2004 204 20x4 LCD Dis
Post by techsupport » Mon Jun 30, 2014 10:47 am
hi,dandlion, You can refer to the following link:
http://www.geeetech.com/wiki/index.php/ ... LCD_Module
Email: forum@geeetech.com
dandlion1
Post by dandlion1 » Mon Jun 30, 2014 12:01 pm
Thank you.
I tried the Sketch in the link you supplied.
Since it was for a 16x2 display, I changed the code from
LiquidCrystal_I2C lcd(0x27,16,2);
to
LiquidCrystal_I2C lcd(0x27,24,4);
Either way, it does not work. I get the same result as I specified in my first post.
Sample Sketch for 24x4 Display.jpg (143.36 KiB) Viewed 183885 times
techsupport
Post by techsupport » Mon Jun 30, 2014 6:08 pm
I think you first operation is right,LiquidCrystal_I2C lcd(0x27,16,2); you can try it again,
If the back-light still come on for a while - then blink - then go off,
You can adjust the potentiometer of blue and press the reset button.
Wilbur1225
Post by Wilbur1225 » Fri Oct 14, 2016 12:37 pm
As the pin resources of Arduino controller is limited, your project may be not able to use normal LCD shield after connected with a certain quantity of sensors or SD card. However, with this I2C interface LCD module, you will be able to realize data display via only 2 wires. If you already has I2C devices in your project, this LCD module actually cost no more resources at all. It is fantastic for Arduino based project.
irenejacob
Post by irenejacob » Fri Aug 25, 2017 6:47 pm
You need to design program and connect all pins of LCD display and Arduino board correctly.
daisyfaith
Post by daisyfaith » Thu Jun 28, 2018 1:16 pm
TimothyRembert
Post by TimothyRembert » Wed Oct 10, 2018 6:44 pm
Thank you so much for this post. Do you want a more creative, meaningful career? Please refer best dissertation writing service to get a meaningful carrier in the future.
DanielWeaver
Post by DanielWeaver » Thu Oct 11, 2018 6:26 pm
Great post. I really appreciate this post that you have posted for us. Are you looking for annotated bibliography writing service Help? Our writers can help you round the clock. Contact us for best grades.
