Good Morning.
I've a DIY Prusa i3 Aluminium with sanguinololu 1.3a and firmware marlin 1.0. Very nice printer until the extruder stepper motor started to malfunction: the filament is not pushed, the motor constantly takes one step forward and one step back when required, instead of moving forward. This problem occurs during printing and through the menu from the LCD.
Attempted solutions:
swap the drivers with the other axes;
buy and replace with new extruder;
replace the wiring;
replace the original sanguinololu with a new same version.
Results:
none.
Moreover, with the new board the movement on the z axis is reversed, the limit switch is not recognized with the risk of damaging the stepper motors which continue to force as they are not controlled by the limit switch.
I'm a bit confused and discouraged
Extruder Stepper Motor stop working
Return to “Geeetech I3 Aluminum”
Jump to
- Firmware
- 3D Printer
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
