kaktus' guide - filament loading even easier and more reliable.
Post by _kaktus_ » Tue Jun 19, 2018 3:31 am
This time something easy to do. Not only is it easy, it is also very helpful.
I'll present a small improvement to make it very easy and reliable to load your filament. :D
The whole process can be divided into two stages.
  1. cutting off the edge of the Teflon tube,
  2. making an additional homing element.
The first step is to cut off the inner edge of the tube with a very sharp pointed knife.
The tube is very smooth and hard, so be careful not to cut yourself.
view of the tubing after the procedure
The next stopper is making an additional element to be placed in the bracket - pneumatic connector PC4-01.
I made it by cutting off the apex of the special screw.
prepared element.
This cut off piece of screw has a height of less than 3mm. It must all fit into the hole. It must not protrude out of it a little.
view after assembly
:D
A sincere greeting to all the owners of the M201. :mrgreen:
Re: kaktus' guide - filament loading even easier and more reliable.
Post by _kaktus_ » Fri Jul 06, 2018 5:37 am
The person who loves details I would like to say that the screw which was used as an organ donor had an inch thread 1/8". ;)
It was an aluminium screw that a fellow man prepared for me on a lathe machine.
Since then, this simple modification has allowed me to easily and reliably load a new filament.
I recommend it to everyone.
algernon
Post by algernon » Mon Jan 07, 2019 3:53 pm
great modification, thank you!
another possibility to print:
Post by _kaktus_ » Thu Jan 10, 2019 3:42 am
Ha ha a beautiful thing.
It is important that the smaller hole has the right diameter. It should be slightly larger than the diameter of the filament. And the slanting edges should be smooth properly.
:lol:
Do you want to share the STL file :?:
algernon
Post by algernon » Sat Jan 12, 2019 10:04 pm
"Do you want to share the STL file"
No problem:
Guide_filament_extrudeur.7z
(4.82 KiB) Downloaded 723 times
