Vertical edges bent
PvvS
Vertical edges bent
Post by PvvS » Thu Nov 08, 2018 12:22 am
Hello, I have a Rostock 301 printer. I print a calibration cube 20mm and I have a problem with vertical edges. It's just blown in, instead of straight. The printer has only the improvement that Drylin Igus is fitted with instead of the rubbers that are already in production. They walk with their axes smoothly and without wills. drivers are original with 1V voltage. With the lower layers, they leapt. I also tried 2208 with whom it goes the same, only much quieter.
Gingko
Re: Vertical edges bent
Post by Gingko » Wed Nov 14, 2018 4:24 pm
How much temperature did you set?
Do you have some pictures or link of videos?
