Rostock 301 Layer fan
ukgreg
Re: Rostock 301 Layer fan
Post by ukgreg » Sun Dec 02, 2018 4:01 am
hi all
I have plugged my layer fan to e extruder 2 and pasted @William's the code to the extruder in repetier hist in slicer configuration (M106 P2 S255) Fan is starting strait away after starting the printer, how do I modify this code and where I should place it to switch the fan on after 3rd layer?
Thanks in advance.
Post by William » Tue Dec 04, 2018 4:22 pm
You can edit it on slice software. Then it will work
klimbo
Post by klimbo » Sun Mar 24, 2019 5:10 pm
hello
i think Indeed the layer fan must be doled out into firmware to be worked effectively by slicer, not physically.
As I can't modifie it without anyone else's input, Could you give a firmware form that would dole out T1 Pwm attachment to layer fan (as it is anything but difficult to do with Marlin on arduino)
