3d Touch GT 2560 Rev A
Kirionet
Post by Kirionet » Sun May 31, 2020 1:43 am
Hi i recently purchased a 3d Touch sensor for my I3 Pro B with GT 2560 Rev A.
During the installation i stuck at this part:
Step1. Remove the Z max connector from the board and replace it with a 3Pin Straight Pin. You need to use soldering iron here.
I don't have any way to do it.
Is there's any other way to install the 3d touch without removing this connector??
Thank you.
Re: 3d Touch GT 2560 Rev A
Post by William » Tue Jun 02, 2020 10:23 am
Hi,it can be adjusted down without removing it.
Kirionet
Post by Kirionet » Thu Jun 11, 2020 4:44 pm
Hi, there's a guide to do that?
thank you
Post by William » Fri Jun 12, 2020 9:44 am
Loosen the screw to move it down, then tighten it
