Hi guys,
I'm a beginner and this is my first print, I suppose that something is wrong. Can you help me?
First print so bad
First print so bad
- Schermata 2020-03-12 alle 18.13.03.png (427.7 KiB) Viewed 4377 times
- Schermata 2020-03-12 alle 18.13.10.png (437.07 KiB) Viewed 4377 times
- IMG_8514.jpeg (650.27 KiB) Viewed 4377 times
- IMG_8513.jpeg (544.09 KiB) Viewed 4377 times
- IMG_8512.jpeg (509.5 KiB) Viewed 4377 times
Re: First print so bad
Hi,you can try to level the hotbed,
The distance between the nozzle and the hotbed is the distance of a piece of leveling paper;
Then check if the nozzle diameter setting in your slice is 0.4,
for the z-axis threaded rod,
you can refer to this: viewtopic.php?f=66&t=69776
Then make your changes accordingly.
I hope this can help you.
