X-Axis not moving
PasWeb
X-Axis not moving
Post by PasWeb » Sat Aug 17, 2019 12:59 pm
Hello together,
I just assembled my new printer and got some trouble with the x axis not moving. I already tried some things on it:
- Switching to the y axis control on the mainboard, it is moveable through y axis movement, but the y axis controlled by x axis is not moving (so motor is not defect)
- Switched the cable, no affect (so cable is working)
- Changed the driver thingis on the board, doesn't help at all, the x axis slot isn't working
Don't know what to do, please help...
Best regards
Pasweb
Re: X-Axis not moving
Post by William » Sat Aug 17, 2019 1:35 pm
Hi, You mean to swap the motor line of the x-axis to the motor of the other axis.
Is the motor also running?
There is no problem with the x-axis motor and motor line.
Then you need to replace the motherboard, there is a problem with the x-axis motor slot.
Post by _kaktus_ » Sat Aug 17, 2019 2:25 pm
Hello.
It is worthwhile to try to improve the soldering pads of the socket.
Maybe there is a cold solder there :?: It is worth to improve the contacts with the hot soldering tip of the soldering iron.
PasWeb
Post by PasWeb » Sat Aug 17, 2019 9:41 pm
Yes, Motor is okay an the cable to the motor also.
That's unlucky, how do I get a new board?
Also I recognized the problem with the z axis not moving properly, maybe I got a monday model? :(
Post by _kaktus_ » Sun Aug 18, 2019 3:01 pm
Hi.
You can describe your problems to your dealer, the controller board should be replaced with a working one.
Post by William » Mon Aug 19, 2019 9:01 am
Hi, You can contact your sales to replace it.
