Adding PETG to the pre-heat menu.
GAQ
Post by GAQ » Sun Jun 09, 2019 10:22 am
I use the pre-heat function quite a lot.
I print from the SD card and I find that if I pre-heat the nozzle and bed, I can give them a while to settle down.
This also allows the bed some time to heat more uniformly.
I print with PETG and I'd like to add this material to the menu list.
Now I've looked at the configuration.h file and find a reference to this, and I've also found a reference in the Configuration_adv.h file.
Is adding PETG to the menu as simple as making the changes below - or is there another file to be changed ?
Or indeed can I not do this at all ?
Found in the Configuration.h file
Existing is...
Code: Select all
// @section temperature
// Preheat Constants
#define PREHEAT_1_TEMP_HOTEND 180
#define PREHEAT_1_TEMP_BED     70
#define PREHEAT_1_FAN_SPEED     0 // Value from 0 to 255
#define PREHEAT_2_TEMP_HOTEND 225
#define PREHEAT_2_TEMP_BED    90
#define PREHEAT_2_FAN_SPEED     0 // Value from 0 to 255
Can I simply change this to...
Code: Select all
#define PREHEAT_3_TEMP_HOTEND 245
#define PREHEAT_3_TEMP_BED    75
#define PREHEAT_3_FAN_SPEED     0 // Value from 0 to 255
Found in the Configuration_adv.h file
Existing is...
Code: Select all
//#define CUSTOM_USER_MENUS
#if ENABLED(CUSTOM_USER_MENUS)
  #define USER_SCRIPT_DONE "M117 User Script Done"
  #define USER_SCRIPT_AUDIBLE_FEEDBACK
  //#define USER_SCRIPT_RETURN  // Return to status screen after a script
  #define USER_DESC_1 "Home & UBL Info"
  #define USER_GCODE_1 "G28\nG29 W"
  #define USER_DESC_2 "Preheat for PLA"
  #define USER_GCODE_2 "M140 S" STRINGIFY(PREHEAT_1_TEMP_BED) "\nM104 S" STRINGIFY(PREHEAT_1_TEMP_HOTEND)
  #define USER_DESC_3 "Preheat for ABS"
  #define USER_GCODE_3 "M140 S" STRINGIFY(PREHEAT_2_TEMP_BED) "\nM104 S" STRINGIFY(PREHEAT_2_TEMP_HOTEND)
  #define USER_DESC_4 "Heat Bed/Home/Level"
  #define USER_GCODE_4 "M140 S" STRINGIFY(PREHEAT_2_TEMP_BED) "\nG28\nG29"
  #define USER_DESC_5 "Home & Info"
  #define USER_GCODE_5 "G28\nM503"
#endif
Can I just change this to...
Code: Select all
  #define USER_DESC_4 "Preheat for PETG"
  #define USER_GCODE_4 "M140 S" STRINGIFY(PREHEAT_3_TEMP_BED) "\nM104 S" STRINGIFY(PREHEAT_3_TEMP_HOTEND)
  #define USER_DESC_5 "Heat Bed/Home/Level"
  #define USER_GCODE_5 "M140 S" STRINGIFY(PREHEAT_2_TEMP_BED) "\nG28\nG29"
  #define USER_DESC_6 "Home & Info"
  #define USER_GCODE_6 "G28\nM503"
#endif
Or will I mess something else up ?
Any suggestions ?
Gerry
GAQ
Re: Adding PETG to the pre-heat menu.
Post by GAQ » Sun Jun 09, 2019 11:12 am
Many thanks vert
I did wonder if I'd be limited to just two settings in the menu.
I can live with just changing the 'Preheat ABS' into 'Preheat PETG' as I will very rarely use ABS.
I'll just have the two options then with the correct preheat temperatures and labels.
Gerry
GAQ
Post by GAQ » Sun Jun 09, 2019 8:32 pm
Hi Vert,
So I'm a little of the way there...
I changed the Configuration_adv.h file and it now reads...
Code: Select all
#define USER_DESC_3 "Preheat for PETG"
- All I've done is changed the name of 'ABS' to 'PETG' ...
I changed the Configuration.h file to read...
Code: Select all
#define PREHEAT_2_TEMP_HOTEND 245
#define PREHEAT_2_TEMP_BED    75
- I've just changed the temperatures...
Now when I go to the menu system, under 'Prepare' - I still get the ABS choices listed...
No mention of PETG at all
However, I do note that the Temperatures are now the ones I want for PETG !
Hence, I think another file is controlling the menu list, but it still uses the variables PREHEAT_2_TEMP_HOTEND and PREHEAT_2_TEMP_BED such that the pre-set temperatures have moved during the update...
I suppose I can live with this !
Gerry
GAQ
Post by GAQ » Wed Jun 12, 2019 7:25 pm
Many thanks Vert !
I noted that my version of 'Custom Commands' was in fact commented out with the " // " at the start...
I've now changed this in line with your posted version.
I see that I do indeed have the power to have 5 commands that I can customise at will, I didn't know this facility existed !
I now have my 5 set up - to 'Home, Level and set the three Bed & Nozzle Material Temperatures all correctly labelled.
Many thanks once again.
Just one quick question... How come I've not seen this facility documented anywhere ? - It's pretty useful.
Gerry
