Prints stopping halfway through
Roozlehorse
Post by Roozlehorse » Sun Jan 06, 2019 5:38 am
Everything seems to be working more or less perfectly now, but my extruder stops working about 20 mins into any print. Is this a common problem? How do I fix it?
This was PLA at 200 degrees, which seems to work for a while.
I've looked here but it's not really any help:
https://www.simplify3d.com/support/prin ... e-of-print
Re: Prints stopping halfway through
Post by William » Wed Jan 09, 2019 11:59 am
1.You can check the temp sensor loose or not
2.You can check the hotend cooling fan work or not
3.You can try to take the hotend off then check the tpfe tube of its inside
Roozlehorse
Post by Roozlehorse » Thu Jan 10, 2019 10:14 pm
Ah I don't think I have a PTFE tube with my printer, could be that causing it?
Martin L.
Post by Martin L. » Fri Jan 11, 2019 5:31 pm
I had the same problem. After I took a faster PC the problem was solved.
Post by William » Tue Jan 15, 2019 9:02 am
You need to check the hotend inside at first..
iamdbain
Post by iamdbain » Sat Mar 23, 2019 9:15 am
I was having a similar problem and it turned out to be the bearing on the movable end of the belt that moves the extruder. I replaced the bearing and no more issues. The bearing was completely shot and locked up without any other signs. I may have over tightened the belt in my zeal to get printing when I first built it. It worked better that I thought up until the little bearing failed. Now 2 years later I am having a nozzle not heating issue, working on that now. Good luck.
