It seems that my newly assembled I3 pro B cannot auto home correctly. When I auto-home on it, The heated bed goes to the end and carries on causing a grinding noise and causing the beds wing nuts to loosen, It is correctly wired up so is it just a faulty endstop or not an issue with the endstop?
EDIT: Turns out I didn't have my cables plugged into the right thing! Ha, well thanks to anyone who replied
Y-axis endstop not working? Solved
Re: Y-axis endstop not working?
You can do a test to check if it's the problem of endstop:
http://geeetech.com/forum/viewtopic.php?f=17&t=60927
If the endstop is broken, try to contact the sales, they will help you replace a new one.
Welcome to Geeetech world:
https://www.facebook.com/groups/315127105604393/
You have checked that the cables are connected in good sequence.
Maybe you mistakenly used other switch outputs?
The contact can also be of poor quality.
