How do you unload filament?
SoupersSB
Post by SoupersSB » Sat Jun 09, 2018 10:25 pm
I am running low on filament and I want to print something big so it would be best to use my new filament. How do I unload the filament from the printer without using any computer program (Using the settings on the printer)???
Re: How do you unload filament?
Post by _kaktus_ » Mon Jun 11, 2018 12:39 pm
Use the options from the Preheat PLA or Preheat ABS printer menus. Next Move 10mm -> Move Z, until the whole filament is pulled out.
Geeetech Prusa I3 M201 Dual extruder Mixcolor 3D printer
bought 2017-12-19, already built, in the cognitive and improvement phase
Geeetech 3D WiFi Module for 3D Printer
bought 2018-04-15, He got a new life, and still lies in a drawer.
PaulB
Post by PaulB » Tue Jun 12, 2018 7:56 pm
Use the preheat PLA option, press the extruder lever down and smoothly remove the filament. Cut the tip off before you use it again.
Feeding the new filament in is a reversal, preheat, press the lever down and feed the filament in.
SoupersSB
Post by SoupersSB » Thu Jun 14, 2018 3:35 am
I don't have the option to move Z, only X and Y
Post by _kaktus_ » Thu Jun 14, 2018 12:19 pm
Well, you can see, I wrote Z by distraction, and I was referring to the Extruder (E). :oops:
I need to be more careful.
I have this possibility in my printer.
Also refer to the Move 1mm option.
SoupersSB
Post by SoupersSB » Fri Jun 15, 2018 1:35 am
I don't have E either
Post by _kaktus_ » Fri Jun 15, 2018 11:49 am
In this case, after heating up the head, the filament must be pulled out manually.
SoupersSB
Post by SoupersSB » Sat Jun 16, 2018 11:15 pm
Do you even have an i3 pro b? I cant just pull it out! it doesn't come out!
Post by _kaktus_ » Tue Jun 19, 2018 12:27 pm
No, I only have one model.
And I really wanted to help you, as you can see I didn't succeed. ;)
If there is really a big problem with removing the filament after the head has warmed up, you may need to open it up.
Perhaps @Gingko will come up with something better. It has access to all models.
Gingko
Post by Gingko » Tue Jun 19, 2018 4:12 pm
Usually, heat up the extruder to 200C, then press the lever, the filament can be pulled out (or push in a little, when melted then pull out).
@Kaktus is right, if it's still hard to do that, try to take off the fan, heat sink and check inside, take pictures if possible.
