Problem with Geeetech A30: Z Axis is 2-3mm above the bed at the start of the print
quilwaxil58
Post by quilwaxil58 » Sat Dec 05, 2020 2:32 am
I got my very first 3D printer and wanted to test it by printing the benchy. So I added the printer in cura via custom fff printer, entered the dimensions, filament size, heated bed etc. After putting in filament and leveling the bed I started the print and the printer started, but the nozzle wasn't nearly where I leveled it, but rather 2-3 mm above the plate. Obviously i canceled the print.
Did anyone have the same problem or know where this may come from? Could false settings in cura be the cause or did I fail at leveling the bed correctly? Or is it something I totally missed?
I researched on the internet and I saw you can set an z offset value in your starting gcode. Should I just try to find a value to lower the nozzle?
Thanks for your help!192.168.0.1 routerlogin 192.168.l.l
RPL-754
Re: Problem with Geeetech A30: Z Axis is 2-3mm above the bed at the start of the print
Post by RPL-754 » Tue Dec 29, 2020 7:12 am
Hello, ce sujet m'intéresse car j'ai le même souci!
