I don’t want it to home in the middle - solved
jbalat
Post by jbalat » Fri Mar 20, 2020 5:52 pm
Is there any way to home off the edge of the bed in front left corner ?
Re: I don’t want it to home in the middle
Post by William » Fri Mar 20, 2020 6:01 pm
Hi, did you do Auto home
you can choose mobile hot end in the screen.
jbalat
Post by jbalat » Fri Mar 20, 2020 6:05 pm
Can you explain how ?
I just press the home button in the middle on the screen.
It homes X then goes to the middle of the bed and goes down to home z
Post by William » Fri Mar 20, 2020 6:16 pm
Hi, You can choose the move key
Then select each axis as needed
According to your needs (such as select X + / Y + ect)
jbalat
Post by jbalat » Fri Mar 20, 2020 7:11 pm
Ok just realised whenever home z is activated even on its own it just goes to the middle of the bed and keeps going down until it hits it and I switch it off
Confirmed all switches working.
This post has now become the same as my other post title z switch not working - best to end this here...
UPDATE
Turn on auto leveling if you don’t have a touch sensor
