Hallo,
ich habe seid kurzen einen Geeetech A30, nun habe ich das Problem das er bei längeren Drucken irgendwann das Filament komplett auswirft und dann einfach ohne Filament weiterdruckt.
Arbeite mit Cura 4.4.0
Firmware: A30_S_VD_V1_57
Kann die G-code Variante bei den Druckereinstellungen eine Auswirkung haben?
Meine Vermutung ist das er bei den Reset der E-Steps mit dem Befehl M92 E0 das Filament auswirft.
Vielen Dank für eure Hilfe
Drucker wirft während Druck Filament aus
Re: Drucker wirft während Druck Filament aus
Hi, Is your extruder motor running in the normal direction?
Or reverse?
If the direction of rotation needs to be changed,
For specific operations, you can refer to: viewtopic.php?f=17&t=60639&p=82054#p82054
Or reverse?
He prints 3 hours without Problems and than he pulls all the Filament out.
He runs 3 hours in the normal direction than he runs reverse an than he runs normal but he put the Filament complete out of the Extruder
Hi, Can you print the test file of the printer normally?
Ja erst bei längeren Drucken wirft er das Filament aus
Hi, Can you provide specific videos?
or If this is the case with just printing a model,
You can re-slice and print.
I print 4 different big Models everytime the same problem...
Can there a problem with the Firmware?
Which G-code variante do i need in Cura?
Marlin, Preprap, repetier or other?
Hi, You need to use marlin,
Maybe something is wrong with your slice,
You can try re-slicing.
Or print a test file.
ok print another test, but when i have the same Problem what shall i do?
Reslice and hope won´t help everytime.
What can i chance to find the Problem...
Can the Firmware make this Problem?
Hi, It's possible that your slice settings have an abort command,
Causes slicing errors.
You can re-slice or use the slicing software to set up the printer again.
