manual levelling positions
KinCatia
Post by KinCatia » Mon Nov 04, 2019 8:46 pm
First is it possible to change where the standard manual levelling positions are (A30).
I'd like to get them directly above the adjusting screws. If this is not possible how can I get the gcode to goto x45 y45 z.1 and pause there and then x285, y45, z.1 and pause there and so on?
I've tried editing an existing Gcode so that it doesn't feed and just lifts goes to my 1st position drops down and pauses and then lifts and on to the next one but so far I can initialize and move to all positions but I can not get a pause command to wait with the nozzle left where I want to check it? Can anyone give me a G-code pause command that will just wait until I want to continue and not go home when it pauses?
Re: manual levelling positions
Post by William » Tue Nov 05, 2019 9:33 am
Hi, You can try to control it by connecting to the slicing software via usb.
KinCatia
Post by KinCatia » Thu Nov 07, 2019 1:42 am
I'm trying to simplify things I don't want to have to connect anything else to it just to level it better, I just want it to run as another print. Simple or so it sounded when when i first thought of it. thanks
Post by William » Thu Nov 07, 2019 9:07 am
:D I find this,you can refer to this:https://www.youtube.com/watch?v=toKVMLWjTn8
KinCatia
Post by KinCatia » Sat Nov 09, 2019 2:19 am
I don't have a problem with levelling I just want to make it easier by setting the height at the adjusting screws.
Jarda3d
Post by Jarda3d » Sat Nov 09, 2019 3:24 am
A10 Slic3r profile: here
