Problem with A30 XYZ not responding to anything but home?
Sa1Wales
Post by Sa1Wales » Sun Jun 23, 2019 8:15 pm
Printer has been working fine but now its not accepting anything, If I home x,y,z the motors work as they should. if I try Bed Leveling from the control panel on the A30 it does not go to any of the 5 spots I click on the screen it is making the bleep noise when I touch the control screen as if its been activated but does nothing also tried this in Simplify 3D and the same, also no responce from XYZ Jog controls on the control screen or in any of the slicer software I own?
The printer isnt even 6 months old yet, but I have had a few problems such as the SD Card reader not working, the Extruder arm was broke off lose in the box ect thanks to Geeetech support for replacing the above, But Whats gone wrong now?
Thanks in advance for any reply.
I have flashed the firmware to see if there was a problem there but the ones I have tried all have the same issue.
Steve.
Sa1Wales
Re: Problem with A30 XYZ not responding to anything but home?
Post by Sa1Wales » Mon Jun 24, 2019 6:02 am
This can be closed after stripping it all down and rebuilding enverything seems to be fine again now.
