Adding another extruder for multi material prints
is it possible to add another extruder to the geeetech a30 as i would like a second one using a y splitter type extruder and just wondered if there is a way to do this ??? using the same firmware do I just need to add it to the motor tool ?? or do i need to take the sd card out of it and change the code and what do i change it to any help would be great
Re: Adding another extruder for multi material prints
What should be the result?
Multicolorprint or print two workpieces at the same time???
Multicolor: you need to make your own firmware. With A30 it's not easy because the A30 using a 32-bit Controller.
To print multicolor it's better and easier to by the new Geeetech A10M!
make your own world - with 3D printing -
My projects on Thingiverse
my own Geeetech A10 firmware
Geeetech A10 LIVE (not always online)
it would be for multicolor and I just got the a30 thinking it was the latest lol 3 after 1 30 after 10 my mistake and a 32bit controller should handle it if an 8bit controller can just don't know if it could be done with this printer not a problem ime making a new delta printer gonna experiment with that on multi-material if all goes well
