Rostock 301 Endstop problem
Midnightcrash
Post by Midnightcrash » Thu Dec 22, 2016 5:05 am
I got a problem with the homing of my Rostock 301.
One bearing activates the corresponding endstop and moves a bit down as it should.
The second stops before it hits the endstop and the third keeps running upwards, pressing against the endstop.
This behavior is independent of the axes.
Does anybody know a solution for this problem or has a suggestion? I tried configuring the options for endstops, axes max min, etc. in any possible way but I can't find the cause of the problem or it's solution..
Cup
Re: Rostock 301 Endstop problem
Post by Cup » Thu Dec 22, 2016 5:06 pm
Did you have all the endstops correctly connected the corresponding connector(X_min-X endstop,etc.)
Then check if the cables of motors on 3 axes has good connections,rewire them if necessary.
And you can test if your endstops work normally by pushing them down(the motors will stop moving) when auto home.
Lami René
Post by Lami René » Fri Dec 23, 2016 2:12 am
Hello Midnightcrash,
Bonjour Midnightcrash,
You can find the original text into English following this original French text.
Vous auriez une vidéo montrant le problème ?
Cordialement,
L'ami René
Do you have a video showing the problem?
Cordially,
Friend René
One for all and all for one !
Post by William » Fri Dec 23, 2016 10:51 am
maybe you can check the endstops by using a multimeter.
Midnightcrash
Post by Midnightcrash » Sat Dec 24, 2016 7:07 pm
Thank you for your replies. I managed to find and fix the problem by testing the endstops by hand while homing. The X-endstop and the Y-endstop crosstalked and that's the reason for the strange behaviour. I rewired and isolated them again, now everything is working.
