I bought a Acryl Prusa I3 X. I've assembled it but i've got a problem with the gt2560.
When i've switched on the printer, the LCD display turned green with two lines of black boxs. I checked the cables for the SD card and the display, it OK.
I've tried to connect the printer to the pc: the driver installation was sucessfull, and the virtual com port was created.
When i plug the printer card, led d4 e d5 turns on simultaneusly for a fraction of second, then led L blink seven times.
When i try to comunicate with the card, using repeiter-host or arduino ide, the led d4 blink with a period of a lot of seconds.
Looking the card led, i've noticed that the rx led (d5) never blink during the connection.
PS The buzzer never beeped.
I will ask for help!
GT2560 not connecting
Re: GT2560 not connecting
Habe you tried reflashing the firmware, I think you can try it,
you can download the firmware for your printer here:
You can also check your board according to the post:
The power is ok (led ON and both 12V leds are on). The serial port/driver it's ok (com8 created by window).
I've tried to load the firmware with both arduino 1.0.6 and arduino 1.06.6, but the system says:
"avrdude: stk500v2_getsync(): can't communicate with device: resp=0x01" (arduino 1.0.6)
"avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM8
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: stk500v2_getsync(): got response from unknown programmer , assuming STK500
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: STK500
avrdude: stk500v2_command(): warning: unknown, code 0x90
avrdude: stk500v2_getparm(): failed to get parameter 0x90
avrdude: stk500v2_command(): warning: unknown, code 0x91
avrdude: stk500v2_getparm(): failed to get parameter 0x91
avrdude: stk500v2_command(): warning: unknown, code 0x92
avrdude: stk500v2_getparm(): failed to get parameter 0x92
Hardware Version: 255
Firmware Version Master : 254.255
avrdude: stk500v2_command(): warning: unknown, code 0x9a
avrdude: stk500v2_getparm(): failed to get parameter 0x9a
Topcard : Unknown
avrdude: stk500v2_command(): warning: unknown, code 0x94
avrdude: stk500v2_getparm(): failed to get parameter 0x94
Vtarget : 3.6 V
avrdude: stk500v2_command(): warning: unknown, code 0x98
avrdude: stk500v2_getparm(): failed to get parameter 0x98
avrdude: stk500v2_command(): warning: unknown, code 0x95
avrdude: stk500v2_getparm(): failed to get parameter 0x95
avrdude: stk500v2_command(): warning: unknown, code 0x96
avrdude: stk500v2_getparm(): failed to get parameter 0x96
avrdude: stk500v2_command(): warning: unknown, code 0x97
avrdude: stk500v2_getparm(): failed to get parameter 0x97
SCK period : 116.6 us
Varef : 6.6 V
Oscillator : 22.897 kHz
avrdude: stk500v2_command(): warning: unknown, code 0x9e
avrdude: stk500v2_setparm(): failed to set parameter 0x9e
avrdude: stk500v2_command(): unknown status 0xc8
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500v2_command(): unknown status 0x01
avrdude: stk500v2_disable(): failed to leave programming mode
avrdude done. Thank you." (arduino 1.6.6)
Using Port : COM8
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Topcard : Unknown
Vtarget : 3.6 V
Varef : 6.6 V
this check.
I've founded the fault: there was a little bit of tin short-circuiting the pins 2 and 3 (TX and RX) of 2560. Now i've refreshed the firmware and it's ok!
Thanks a lot Toy!
Thanks a lot Toy!
Hi! I have the same problem:
New printer Acryl Prusa I3 X. Board gt2560.
I didn't try to plug the printer card.
When i try to comunicate with the card, using arduino ide, one led are blinking.
The power is ok (led ON and both 12V leds are on). The serial port/driver it's ok (com3 created by window).
I've tried to load the firmware with both arduino 1.8.4 and arduino 1.0.1, but the system says:
Binary sketch size: 115,760 bytes (of a 258,048 byte maximum)
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x10
this check.
avrdude: stk500v2_command(): failed miserably to execute command 0x11
How can I solve this problem? Is the board broken?
Thank you!
this check.
Thank you!
Obviously, you need to replace a new board.
