marlin 1.1.9 gt2560 rev a+ and mmu
v tec
Post by v tec » Mon Oct 08, 2018 2:58 am
hi after have resolve my probe setting, i want know if it s possible to set the mmu kit from prusa with this firmware and my motherboard?
and if not possible, how to set for a diamond hot end?
where write, than slot 3 is for z axis (2 stepper nema 17 on 1 slot= divers ok?), slot 4= extruder 1 slot 5= extruder 2, slot 6= extrudeur 3
where adjust the step per unit for each
where tell than there is only 1 heater and 1 sensor for all
we can use pva-s and pla for exemple in this system? for print support and pla with the same hot end
thanks
aarli
Re: marlin 1.1.9 gt2560 rev a+ and mmu
Post by aarli » Mon Oct 15, 2018 3:28 pm
As of now you can't use MMU and mixing extruder together. That would require pretty big firmware hack. Also no slicing software support this configuration.
Either use MMU with single filament hotend, or mixing hotend without MMU
Geeetech A10 (with mods) + Geeetech A10M
Repetier Server on Raspberry PI 3, connected to printers for remote printing/firmware uploads.
Slic3r Prusa Edition, Simplify3D, Ultimaker Cura, Repetier host on the PC
v tec
Post by v tec » Mon Oct 15, 2018 7:12 pm
thanks, you mean diamond head by "mixing hotend without MMU"
aarli
Post by aarli » Mon Oct 15, 2018 8:15 pm
Yep
v tec
Post by v tec » Tue Oct 16, 2018 1:19 am
do you know this marlin 1.1.9?
