M211 S0 Not working.
Post by 156801 » Tue May 29, 2018 6:31 pm
I installed a BL Touch and was trying to set the offset on the z axis s by using the M211 S0 command to disable the soft end stop.
For some reason this command does not work the board is a gt2560 on a geeetech I3 Pro B W.
Any help would be appreciated.
Robert
Gingko
Re: M211 S0 Not working.
Post by Gingko » Wed May 30, 2018 3:16 pm
Seems that marlin doesn't support "M211" code.
I guess you can set z offset directly by M851.
Post by 156801 » Fri Jun 01, 2018 4:31 pm
Was using Repetier which I found out does not support turning off the soft endstop.
I tried Easyprint 3D and worked no problems.
Thanks for the help.
