Installed 3 pins for bed leveling sensor, board dead
brotherchris
Post by brotherchris » Fri Mar 10, 2017 11:06 am
I soldered on 3 pins to my GT2560 board to add the geeetech bed leveling sensor just like the guide says. When I tried to plug it in and use it, only the 2 green power lights come on and the board gets really hot. The only thing that works is the fan. Any idea what I shorted out? I just removed the max z stop plug and put pins in its place.
Thanks.
gemini0090
Re: Installed 3 pins for bed leveling sensor, board dead
Post by gemini0090 » Mon Mar 13, 2017 5:31 am
have you checked if your card is the GT2560 or GT2560 A +. the difference is that in A + is already the connector for the sensor separately from the other connectors. if you've connected the wrong one could cause problems as you say.
brotherchris
Post by brotherchris » Wed Mar 15, 2017 12:27 am
Mine is the old style, it doesn't have the sensor pins. I will be ordering a new board.
bang
Post by bang » Thu Mar 16, 2017 2:01 pm
Did you solder the 3-pin connector in the place of Z_max as the manual describes?
brotherchris
Post by brotherchris » Fri Mar 17, 2017 2:37 am
I did, it looks like I grounded the signal connector out, now it is burned up.
bang
Post by bang » Fri Mar 17, 2017 1:53 pm
Sorry to heat that...
wiccan2
Post by wiccan2 » Thu Jul 20, 2017 7:37 pm
Just in case anyone else has similar issues I got around the need to solder when installing my 3d touch.
It turns out that if you don't need the 5th stepper you can steal 5v from it's socket.
I describe it here: http://antony-jordan.co.uk/3d-touch-tut ... tml#wiring
The bottom two pounds on the socket to the right provide ground (bottom) and 5v. The cabling might not be as neat but there is no longer any need to risk soldering.
Hope this prevents your issue for others in the future.
