Page 3 of 4
Re: My printer don't print
Posted: Sat Mar 28, 2020 10:17 am
Hi, Normal room temperature,
The thermistor temperature is around 80kΩ,
Whether the wiring at the hot end is loose?
Posted: Sat Mar 28, 2020 5:16 pm
by Briciou62500
No the wiring is good
Posted: Sun Mar 29, 2020 3:59 am
by Briciou62500
There must be a false contact, on the heating bed, it is at -19 ° C then 17 ° C re -19 ° C then 17 ° C ...
Posted: Mon Mar 30, 2020 10:23 am
Hi, are you referring to the temperature change of the hot bed?
Thermistor of the hot bed is at 80kΩ at normal temperature
Can you provide a question video?
Posted: Tue Mar 31, 2020 1:49 am
by Briciou62500
Between blue and green, the multimeter is on 200k ohm.
The value on the screen is 5.2
Posted: Tue Mar 31, 2020 1:51 am
by Briciou62500
Today my bed don't heating
Posted: Tue Mar 31, 2020 10:36 am
Hi, your hotbed thermistor is broken,
you need change it.
Posted: Tue Mar 31, 2020 11:09 pm
by Briciou62500
So, I just saw that it is more complicated than that, when the bed is plugged into the box (power supply, motherboard ...) I have 5.2 but when I unplug the cable, I have 122. The multimeter is still the 200k caliber.
Posted: Thu Apr 02, 2020 3:14 pm
by Briciou62500
It is break or not ?
Posted: Thu Apr 02, 2020 4:04 pm
Hi, based on your test data
This is not normal.
