SD Card Problem
Posted: Sun Jan 15, 2017 4:41 pm
by DoubleK
Hi my problem is that i cannot print from sd card without computer. On the panel i see the file, after enter the display shows me it is printig but it do nothing. I have a sandisc sdhc 4gb card. Is this the problem from the sd card or is the problem the sd card reader?
Re: SD Card Problem
Posted: Wed Jan 18, 2017 11:59 am
by bang
I guess it is the SD card...
All the .gcode files in the card have the same problem?
Did the bed and extruder heat up after you clicked on the file?
Re: SD Card Problem
Posted: Wed Jan 18, 2017 11:22 pm
by DoubleK
No the bed and the extruder did not heat after i start the print job
Re: SD Card Problem
Posted: Thu Jan 19, 2017 5:57 pm
by bang
DoubleK wrote:No the bed and the extruder did not heat after i start the print job
So all of your files in the card had the same results?
Did you check the gcode of the problematic file?
Was it OK?
Re: SD Card Problem
Posted: Fri Jan 20, 2017 1:24 am
by DoubleK
Found the failure, i saved the files on the sd card with binaryformat for repetier firmware and then printer say wait for user and do nothing. I must disable this option and then it works.But when the printjob is longer as 2 hours it stopped without no message . Post can be closed, thank you.
