SD Card
SD Card
Got a issue with the SD card ... when first plugged in, it said "SD card removed".... its a M201 and has two SD card holders one on the board...one on the lcd...useing the one on the lcd it keeps giving that error...seen it work once ...said "SD card OK" hasn't worked since....doesn't matter which card i stick in there...have a tried and true card from my Pro C....
Re: SD Card
wierd...how about format the SD card? and the tiny card on the mainboard, could it work?
Re: SD Card
It works fine now ....the card holder on the lcd board works fine after i swabbed it out with alcohol....some sort of film on the contacts....works great now...working on the squeaky coming from the brass threaded nuts and the threaded rod....at times the squeaking can get quite loud...
