Re: My slicer settings
Posted: Tue May 19, 2015 11:18 am
No he intentedo. Voy a probar.
https://www.geeetech.com/forum/
la temperatura del extrusor debe ser 240.ingsergio wrote:Fue mejor. Se imprimio completo. Con pocas fallas. Lo unico es que aveces no sale filamento cuando esta haciendo la capa y tambien aveces se corre el solido y toca cancelar la impresion.
When printing, you can rotate the knob on LCD anticlockwise to lower the speed, you can see the percentage on the thirdline of LCD.Jsantos1214 wrote:Hello,
i haven't tried these settings yet. but would this help with the bumpy look? so far my prints have been not so great. i would like to print a design but if its going to be bumpy looking its not going to work with my design. how can i go about doing a fine slow print where i wont have bumps on the print?
Tell me please why the settings are totally different compared to those files you uploaded here? It's all different between this "Slicer config" and "Slicer settings", I don't understand lolzhangxueyou wrote:You can also load the configuration file too.Open slic3r in Repetier Host:
thankyou so much!!zhangxueyou wrote: ↑Fri May 15, 2015 8:58 amLa velocidad de extrusión es 95 mm / s. Se ha establecido en el firmware.ingsergio wrote:Saludos zhangxueyou.
Ya estoy imprimiendo. Lo unico es que sale como remontada la figura. A que velocidad maneja el motor del extrusor?
Si desea reducir la velocidad de impresión, Puede girar el saber en la pantalla LCD. Como se puede ver en la tercera línea de la pantalla LCD, "FR 100%" is default printing speed. Stellar Futures Delta Exchange
Traduzco del Inglés al Español en Google traducir, espero obtendrá mi punto.
