Page 3 of 4
Re: LCD 2004 Panel Only Showing Blocks
Posted: Wed Sep 23, 2015 6:32 am
by cpt1nsano
Thanks, did that already though. Problem is that instead of the display working, the hot bed heater and it's LED start turning on and off in a 0.1 second cycle.
Posted: Wed Sep 23, 2015 11:08 pm
by Mark
"the hot bed heater and it's LED start turning on and off in a 0.1 second cycle"
Did the hotbed and LED work well when printed with SD card?
Posted: Thu Sep 24, 2015 12:05 pm
by cpt1nsano
Got it fixed. Compiled my Marlin1.1 code with Arduino 1.6.5 and then uploaded with AVRDUDE from 1.0.1. Everything works fine now. Just wish I could upload direct from 1.6.5 some problem with bootloader mismatches I think. Not going to worry though. Going to upgrade to a Ramps 1.4 anyway. Thanks for the help.
Posted: Sat Oct 03, 2015 3:45 am
by skysurfer
Hi together,
i am a guy from Germany and first i must say sorry for my bead englisch.
I bought a Acrylic Geeetech I3 Prusa Pro B with GT2560 Board and have now also the issue with the black showing blocks in the LCD.
At first the display, after assembling the printer, works fine, i could move the axes and so on.
After connection with PC over USB (drivers are installed) and likes to work with the Repetier Host V1.5.6 i got this issue with the blocks after i powered the printer off and on without connected USB Cable.
Can i have the firmware to reburning ?
What is happen after reburning with the configurations values ?
Will this values deleted ?
Have you this values also in a file for uploading to the printer ?
What is Ramps 1.4 ?
Sorry for this many questions.
Posted: Sat Oct 03, 2015 8:56 pm
by Mark
download the firmware here.
you can refer to the link here to reburn the firmware:
Posted: Sun Oct 04, 2015 4:51 pm
by skysurfer
Hi Mark,
many thanks for your help.
now i have try it so much to burn the firmware.
By burning with Arduino 1.0.1 i get allways the follow error message:
"avrdude: stk500v2_ReceiveMessage(): timeout"
i have try it wit and without power on from the printer.
I have trie it with 2 PC's and by bouth the same.
I work with Windows 7, one have 32-bit and the other 61-bit Windows 7.
Can it be, that the bootloader from the GT2560 is broken ?
or the USB interface ?
Have you a idea what can be happen, so i can slove this issue ?
Posted: Sun Oct 04, 2015 5:10 pm
by Mark
How about unplugging all other parts in the board and just with the USB?
I find an article here and maybe it can help you.
http://stackoverflow.com/questions/1964 ... ge-timeout
Posted: Sun Oct 04, 2015 11:37 pm
by ettiennem
I loaded the firmware attached to this thread to my i3 X with GT2560, now the extruders doesn't work any more. It worked fin until I updated the firmware!
Posted: Mon Oct 05, 2015 9:21 am
by Abelipokwen
Hi. skysurfer.. Sorry i bad in english.. your problem look like same with me before.. i buy 3d printed in ebay but it work 2 hour only and show black cell, Can't load firmware arduino.. my board problem is Cristal 16Mhz Stuck not start, i put multimeter set mode Diod or Beep, cable Black GND and Red Cristal Pin in second. now it work..
Posted: Tue Oct 06, 2015 10:06 pm
by skysurfer
Hi Mark,
Many thanks for your help, but the USB was not defect.
The issue was the baudrate
1. from Arduino environment.
I have changed the baudrate by the serial monitor to 9.600 Baud.
After that i could upload your sendet Firmware and it runs perfectly.
But i could not work with Cura or Reptierhost. i got allways a error message about the serial interface.
2. the baudrate from the Firmware.
i changed in the configuration sketch the baudrate from 250.000 to 115.000 and load this firmware up to the printer.
Now, it works perfect.
