EasyPrint3d that supports a dual nozzle i3 pro c ?
Softfoot
Post by Softfoot » Tue Oct 01, 2019 9:50 pm
Having just finished building my "Pro C with dual extruders" I installed EasyPrint 1.2.6 but find there is no way to enable/setup 2 extruders.
If I change the number of extruders from the default 1 to 2 it accepts the change but never asks for the offsets and the pull-downs that allow the choice of extruder only show 1.
In addition, running the slicer works for "1" but throws an exception if set to "2".
Is 1.2.6 supposed to support 2? If so, how do I set it up ??
Regards,
Bob
Admin
Re: EasyPrint3d that supports a dual nozzle i3 pro c ?
Post by Admin » Sat Oct 05, 2019 1:22 pm
hello,
Easyprint3d does not support DUAL NOZZLE
Admin
Post by Admin » Sat Oct 05, 2019 1:23 pm
I suggest you use repetier-host or cura
