Easyprint software for WINDOWS
Re: Easyprint software for WINDOWS
Same problem for me as of September. No english version as least from the installer. I got it installed but have no idea what options I've selected. Once installed, it opened in English for me but I could not get it talking.
And which version of the application do you talk aboutSirSunshine wrote: ↑Sun Sep 02, 2018 8:23 pmSame problem for me as of September. No english version as least from the installer. I got it installed but have no idea what options I've selected. Once installed, it opened in English for me but I could not get it talking.
Help > About says 1.2.3
Thanks.
Thanks.
@SirSunshine Delete configuration folder and then try to install V1.2.6
Hey guys!
i'm having some difficulties to make a proper setting in easyjet...
here's my setup:
Win 10 with easyjet 1.2.6
Prusa i3 wood, axis and extruder are calibrated
PLA 1,75mm
seems like the extruder does not apply enough material, see picture.
when i try to set the noozle size to 0,3 mm or 0.3 it automatically sets to 3, same happens when i try to change the retraction.
anyway a print with default settings is very unsatisfying.
btw importing configs is not possible too.
has anyone a clue about this?
here's my setup:
PLA 1,75mm
- 2018-09-04 at 00.24.42.jpeg (94.91 KiB) Viewed 549225 times
Have you tried it on repetier-host?Willem wrote: ↑Tue Sep 04, 2018 6:28 amHey guys!
here's my setup:
PLA 1,75mm
You can download this file then test it
@Willem
Try to set "material flow"
Ginko...
This might also be a good place to explain where the "configuration folder" really is....
See here:
Second link.
http://geeetech.com/forum/search.php?ke ... t+app+data
The problem was about something else, but the information remained.
In different versions of Windows OS, folder changed location.
See here:
Second link.
