Easyprint software for WINDOWS
Post by William » Tue Jul 10, 2018 10:44 am
The version of Easyprint 1.2.6(Beta)
:D
Note
-------------------Chinese------------------
1.修复装载默认设置时软件崩溃
2.修复了耗材流量设置无效的BUG
3.增强了切片稳定性
4.增加了螺旋化选项
------------------ -English-------------------
1.Fixed bug:Load the default setting software crash
2.Fixed bug:The setting of filament flow not useful
3.Improve the stable of slicing
4. Add the Option:Enable Spiralize
Link:
http://geeetech.com/firmware/EasyPrint%203D.exe
Known bug:
Since this version is the version for beta.
Please ignore it and it will not affect the use.
Note:
-------------Chinese-------------------------
EP 1.2.3
Bug fixes:
修复了打印速度设置无效的BUG
修复了固件更新无法开始的BUG
修复了部分标签/菜单显示错误的BUG
删除掉了无意义的切片参数
New features:
加入了最大加速度的参数设置
加入了材料流量的设置
细化了打印速度的设置选项
调整了三维视图的部分UI
优化了内部文件的组织结构
加速了系统对于程序组件的加载
安装包内置.Net framework4.0与VC++2015
-----------------English----------------------
EP 1.2.3
Bug fixes:
Fixed bug: print speed setting is invalid
Fixed bug: firmware update could not be started
Fixed bug: some tags/menus displayed errors
Deleted meaningless slice setting
New features:
Added parameter settings for maximum acceleration
Added filament flow settings
Redesign print speed setting options
Adjusted part of the UI for the 3D view
Optimized the organization of internal files
Accelerated system loading of program components
Add Installation package built in.Net framework4.0 and VC++2015
You can download it from this link:
http://geeetech.com/firmware/EasyPrint3D.exe
If you can download it by the link ,
Refer to this link:
https://drive.google.com/open?id=1JD76V ... j5L4LRWzKp
The version of Easyprint 1.2.0
Note:
Add the language of Russia
Fixed the info of some printer firmware version display not correct
Fixed the problem of upload firmware failed
Fixed the problem of the profile of download
You can download it from this website:
If the link of the download doesn't work
Refer to this link:
https://drive.google.com/open?id=1UDWMa ... Ccb9IzJ-kk
Enjoy it!
rogerio53
Re: Easyprint software for WINDOWS
Post by rogerio53 » Fri Jul 20, 2018 4:34 pm
Installer in English, please.
InnocentOne
Post by InnocentOne » Fri Jul 20, 2018 10:52 pm
Yes, english version, please... what should we do with this chinese version?
Alex-w
Post by Alex-w » Sat Jul 21, 2018 2:07 pm
@rogerio53 @InnocentOne
Sorry for our carelessness. we will upload a version default in english.
But if you had installed the chinese one, you can switch UI language at the top menu.
"配置->语言" or "config->language"
Kibo
Post by Kibo » Mon Aug 06, 2018 8:31 pm
I can confirm that with 1.2.3, the print speed setting is now working. However I am experiencing a major bug:
I cannot adjust the filament flow settings. The value is set to 250 % and whatever value I enter, the G-Code does not change. I am currently having constant underextrusion due to the extruder clicking when it is trying to feed too much filament (250 % flow rate).
I reinstalled the 1.2.0 version and the print is fine.
Please confirm.
Besides, the button for the default setting in the slicer menu is not working, but returning an error message.
The settings for wall thickness etc. still do not work properly. I have to enter e.g. the value 6 to have a wall thickness of 3 lines.
I am using a Geeetech I3 pro W | Firmware V1.0.04
Alex-w
Post by Alex-w » Tue Aug 07, 2018 11:50 am
Thanks @Kibo
I will confirm and fix it in a few hours
Post by _kaktus_ » Tue Aug 07, 2018 1:13 pm
Perhaps the laws of physics cannot be overcome by the settings in the program. ;)
MarkFish54
Post by MarkFish54 » Thu Aug 23, 2018 7:26 am
Which one is English.....
Gingko
Post by Gingko » Tue Aug 28, 2018 4:58 pm
Hi, please try version 1.2.5
MarkFish54
Post by MarkFish54 » Sat Sep 01, 2018 8:50 am
OK I found it, or I found version 1.2.6 and installed.
Now each time I go into Easyprint "1.2.6" it tells me that a upgrade is available "Would I like to upgrade to version 1.2.3" Would it be to much to ask, Please fix this.....
Thank you in advance....
Locked
