Does anyone here have a good setting for Repetier-Host ABS printing with
Acrylic Geeetech I3 pro and Sanguinololu 1.3a.
Repetier-Host setting on ABS print
Re: Repetier-Host setting on ABS print
Please tell me the filament diameter and nozzle diameter.
Filament 1.75 , nozzle 0.3mm
ABS filament.
ABS filament.
How about setting for 1.75 and 0.4 ABS?? Thanks
you can use the settings above too, just need to change the diameter of the nozlle to 0.4mm.
http://www.repetier.com/#documantation
Also you can refer to the link here to use the repetier host:http://www.repetier.com/#documantation
I followed these setting but the print out is horrible. Any good advise?
- Abs hollow cube
- 20180806_220632.jpg (239.55 KiB) Viewed 10649 times
