Rostock 301 1.0.3 Firmware Problem
JohnQuix
Post by JohnQuix » Thu Nov 02, 2017 10:12 am
After upgrading to 1.0.3 my printer does not recognize any negative coordinate values. so now it can only travel in the positive areas away from the origin. When I tried to go back to 1.0.2 it bricked my board and I was only able to use EasyPrint to get it back to 1.0.3 which obviously doesn't work.
Re: Rostock 301 1.0.3 Firmware Problem
Post by William » Thu Nov 02, 2017 4:13 pm
Obviously, you need to upload the firmware again.
WildWolf
Post by WildWolf » Fri Nov 03, 2017 9:12 pm
Same problem here...
The printer, with the latest firmware, cannot move to negative coordinate...
I tried with manual control on software, manualy send a Gcode command and using the LCD movement in the printer!!!
In all case, the head cannot move to negative coordinate!!!
Another BUG....
If i try to move the head (or use the extruder) without Homing, the head crash to the endswitch!!!
Post by William » Mon Nov 06, 2017 12:03 pm
You should upload your firmware 1.0.2 refer to this link:
viewtopic.php?f=20&t=60425
JohnQuix
Post by JohnQuix » Fri Nov 10, 2017 1:35 am
I uploaded the 1.0.2 firmware and it failed so I had to reload the 1.0.3 firmware which still has the problem after loading it again.
Post by William » Fri Nov 10, 2017 9:11 am
What tools are you using?Any wrong tips or error code?
JohnQuix
Post by JohnQuix » Fri Nov 10, 2017 9:55 am
Using easy print to upgrade to 1.0.3
I tired using the method here on the forums at the end it said FAILED! I can’t remember if there was an error code. I can try to upload 1.0.2 tomorrow to see if there is a specific code.
In the meantime since the 1.0.3 firmware is obviously bad should you maybe pull it?
Post by William » Fri Nov 10, 2017 1:25 pm
You should via USB port send G-code G91 to the printer, then send G1 code.
Users browsing this forum: No registered users and 23 guests
