Prusa i3 Aluminium unexpected motion problem
balearic.dynamics
Re: Prusa i3 Aluminium unexpected motion problem
Post by balearic.dynamics » Wed Jan 06, 2016 5:49 pm
I am supposing the same. Or a problem related to the wrong management of long / integers during compilation, wrong casting or similar. Now I am doing a counter-test:
Set the slicer feed rates to almost absurd values, like 1 and 2 Then the result in the generated gcode is between acceptable ranges. If this work, I will try to modify the firmware feedrate calculation simplifying the formula and splitting it in more parts.
As I have finished the test cycles I will post an update anyway.
Enrico
balearic.dynamics
Post by balearic.dynamics » Fri Jan 08, 2016 6:21 pm
Mark,
Now setting these low values the printer moves. Not fine because the values are too low in some cases but the problem on the z-axis occurs only when there is normal feedrates set in the slic3r with the Repetier host (take in account that I have saved the various kind of slic3r settings.
Exploring the firmware Medel_main.cpp it seems that for some strange reason the feedrate forumla
Code: Select all
feedrate/60
does not do the float division correctly. And this has not so much sense for me.
Hope you can suggest something else...
Thank you. Enrico
Post by Mark » Sat Jan 09, 2016 3:43 pm
sorry don't quite familiar with the firmware and formula...guess the mainboard is faulty somewhere...
Users browsing this forum: No registered users and 11 guests
