How to install the firmware for GT2560
Re: How to install the firmware for GT2560
Post by Mark » Mon Feb 08, 2016 8:07 pm
M32 is used to start a SD card print, I wonder could it be used the end gcode?
Olympian
Post by Olympian » Tue Apr 26, 2016 2:52 am
I have installed firmware on my rostock mini g2s pro but have problems.
If I clear log on fepetier host and hit reset button on lcd2004, the software reports Marlin 1.0.3 dev
And my lcd screen is blank...cannot control printer from repetier host.
Earlier I had installed firmware reporting as Marlin 1.1.0-RC5
WHAT MARLIN Version should I be seeing?
BTW .. The firmware that came installed with the printer also reported as Marlin 1.0.3 dev
I had no motor control with it either.
Interestingly, the Marlin 1.1.0 RC5 version at least held the steppers, while the other leaves them free to move by hand.
I may have a faulty lcd2004 since it never gave me the menu even when display worked with original firmware.
I am quite frustrated.
Post by Mark » Tue Apr 26, 2016 3:54 pm
You can download the firmware for your G2S here:
It's based on marlin 1.0.3 dev.
And the motors, first make sure they are all correct connected, and then check the driver voltage as this link shows:
Also the LCD, you might have mixed the wirings of LCD and SD card, check out this link:
http://www.geeetech.com/forum/viewtopic ... 23&t=17040
wuki
Post by wuki » Wed Apr 27, 2016 11:18 pm
the board GT2560 does not work can not install the firmware for days .
Myster
Post by Myster » Mon May 09, 2016 2:41 pm
How long should the upload take? I Have a brand new Geeetech Prusa i3 x, and have followed these instructions, but the Arduino software seems to be freezing on the upload (now going on 10 minutes). I have previously communicated and printed via Repetier, so I know com is OK. I'm on Windows 10, using Arduino 1.0.1, as instructed.
Thanks for your help.
Admin
Post by Admin » Mon May 09, 2016 3:06 pm
it is better to power it up, not just the USB cable, this will speed it up.
Myster
Post by Myster » Tue May 10, 2016 12:40 am
Thanks. Does it usually take longer than 10 minutes to flash? Arduino IDE compiles, then stalls at "uploading". Not sure how long to wait before assuming something is not working.
guspellic
Post by guspellic » Sat Jun 11, 2016 11:20 pm
I'm having trouble to make my Delta G2S work.
First, I'm getting the 2 lines of squares at the LCD. To try to solve that, I'm trying to update the firmware, but I'm getting the "avrdude: stk500v2_ReceiveMessage(): timeout" error.
I'm using Arduino v 1.6.8 in a Mac with OSX El Capitan.
Any thoughts on this?
Thanks,
Gustavo
Post by William » Mon Jun 13, 2016 11:50 am
guspellic wrote:Hi,
Thanks,
Gustavo
Hello,Gustavo
You can have a try like this link shows:
http://www.geeetech.com/forum/viewtopic ... 20&t=17102
guspellic
Post by guspellic » Mon Jun 13, 2016 7:11 pm
William Kwok wrote:
guspellic wrote:Hi,
Thanks,
Gustavo
Hello,Gustavo
Hi William,
Thanks for your answer. Actually, the solution was very simple (but hard to find out). Due to a minor misalignment when I assembled the LCD panel, the reset button was continuously pressed...
Tks anyway.
Gustavo
Locked
Users browsing this forum: No registered users and 48 guests
