Page 3 of 5
Re: How to upload the firmware to Sanguinololu/GT2560
Posted: Mon Jul 13, 2015 5:57 pm
by Sherry
regarding to the extruder not working,please do the following step.
1.the extruder will move until the temperature was raise to 180 degrees for PLS,240 degrees ABS.Please check whether the extruder is heated up.
2.please swap the driver board with x-axis,if x-axis is working,the driver board is good.
3.please connnect the motor wire of the extruder to x-axis .if working,the stepper motor is good.
4.please redownload the firmware.
If all above methods do not work,please contact the customer service.
Posted: Mon Jul 20, 2015 6:18 pm
by BQSOLDest
Good afternoon!
Tell me where you can download the firmware for Sangoinololu 1.3a?
Posted: Fri Aug 14, 2015 3:00 pm
by Robo Techy
As a followup to the extruder not turning.... It was firmware. I was sent new firrmware and it worked when I powered down the printer and just let the board be powered from the USB port to reflash it.
Posted: Fri Aug 14, 2015 3:02 pm
by Robo Techy
The issue was resolved with a new firmware flash. To get it to work, I had to power the board with just the USB with the printer off.
Re: LOST on how to??
Posted: Sat Sep 12, 2015 5:41 pm
by pit
zhangxueyou wrote:For GT2560, ignore step 2-4
6. Open folder "I3_Sanguinololu"(files of Marlin firmware), select all the files (59 in all) and drag them into arduino.
Could you add a link to I3_Sanguinololu? There is no such a folder in standard Malin firmware, as it, for example, can be downloaded from
https://github.com/MarlinFirmware/Marlin
Posted: Thu Sep 17, 2015 5:36 pm
by Mark
what's your printer type? I'll send it to you.
Posted: Sun Sep 20, 2015 3:19 am
by megas
am as dissapointed as you are my friend i cant get the firmware for gt2560 and they wont provide the motor pinouts
i think we can buy a ramps board and replace the gt2560 its very useless to me once we do so we can configure the ramps quite fast as there are very many firmares
can some one mail me the firmware for the gt2560 before i throw it away???????
morris
Posted: Mon Sep 21, 2015 5:24 pm
by Mark
帖子由 megas » 周日 9月 20, 2015 3:19 am
morris
See if I can help you here, what's the type of your printer?
Posted: Mon Oct 12, 2015 10:15 am
by braza
I get a problem with the X axis move in the opposite direction, I follow the instruction shown here ,but i found a
issue I can not found the folder mention in the step 6. Open folder "I3_Sanguinololu"(files of Marlin firmware), select all the files (59 in all) and drag them into arduino.
I download already the Arduino 1.0.1 and the sanguino-0101r1 , but I just can not found where is the 13 Sanguinololu
files.
Can I get help with this?
Posted: Mon Oct 12, 2015 2:57 pm
by Sherry
braza wrote:I get a problem with the X axis move in the opposite direction, I follow the instruction shown here ,but i found a
files.
hi,you can down the firmware for sanguinoloulu in the link:
http://www.geeetech.com/forum/viewtopic ... 3&start=20
